Topmount manifold setup...
bgsr240
Car: 90 240sx hatch sr20det redtop gt28rs-sold 89 240sx hatch S14 sr20det blacktop
I am going to be buying an S14 sr20det and installing it in my S13. I am planning on keeping the mods to the engine small at first, but plan on swapping cams and turbo later. Since the engine is way easier to work on while its out of the car I plan on upgrading the clutch and switching to a topmount manifold setup. This way when I go to the bigger turbo all I have to do is unbolt it off the top of the manifold and bolt the new one on. The problem is that the T28 has an internal wastegate. Is there anyway of keeping the t28 wastegate closed short of welding it shut since I plan on using it at first? I have all the tools and skill necessary to fab anything that I might need. I just need some advice and dont want to mess up the T28 because I might want to use it on a redtop swap later. Thanks.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
just weld the wastgate actuator arm on the turbo so the wastegate is in the closed position
bgsr240
Your right that would be a lot easier...
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
Most if not all of the nice name brand manifolds are t3 flanged i believe. That is something to consider!
bgsr240
So you are saying that the t28 wont bolt up? I could just tig a different flange onto the manifold.
S13FASTBACKSR
Car: '92 Fastback SR powered
ya i was thinking of doing that before..buying a t3 manifold and cutting the flange off and cutting off the t2 flange from my aftermarket manifold and swapping them so i could top mount the t2 turbo
