tigerclaws1318 wrote:
4th Gear tops out at 130mph and I would know cause thats the gear I ran it in when doing my dyno pulls. lol
Not validating his claim, but if you run the gear ratios (available from here http://blogs.thecarconnection....specs) and tire size through gearcalc (available from here
http://www.locost7.info/gearcalc.php )
4th gear is close to 6000 RPM @ 150
Theorectically possible, of course gear calc doesn't adjust for coefficient of friction or tire deflection (which impacts rotation diameter)
Output:
GearCalc v2.0.0.3 Copyright ©2001, Peter Ogden Gear Ratio, Speed and RPM Calculator
Gear set: Manually entered values Gear 1 2 3 4 5 Final Ratios: 3.540 2.260 1.470 1.000 0.830 3.130
RPM Limit: 7000 RPM @Peak Power: 6400 Tyre Size: 235/45 x 18 Tyre Diameter: 26.33 in Tyre Circumference: 82.72 in
Gear Mph per 1000 RPM Mph @6400 RPM Mph @7000 RPM -------------------------------------------------------- 1 7.07 45 49 2 11.07 71 78 3 17.02 109 119 4 25.03 160 175 5 30.15 193 211 Mph RPM (in Gears) ------------------------------------------------- 1 2 3 4 5 ------------------------------------------------- 5 707 452 294 200 166 10 1415 903 587 400 332 15 2122 1355 881 599 497 20 2829 1806 1175 799 663 25 3536 2258 1468 999 829 30 4244 2709 1762 1199 995 35 4951 3161 2056 1399 1161 40 5658 3612 2350 1598 1327 45 6365 4064 2643 1798 1492 50 ........ 4515 2937 1998 1658 55 ........ 4967 3231 2198 1824 60 ........ 5418 3524 2398 1990 65 ........ 5870 3818 2597 2156 70 ........ 6321 4112 2797 2322 75 ........ 6773 4405 2997 2487 80 ........ ........ 4699 3197 2653 85 ........ ........ 4993 3396 2819 90 ........ ........ 5286 3596 2985 95 ........ ........ 5580 3796 3151 100 ........ ........ 5874 3996 3317 105 ........ ........ 6168 4196 3482 110 ........ ........ 6461 4395 3648 115 ........ ........ 6755 4595 3814 120 ........ ........ ...... 4795 3980 125 ........ ........ ...... 4995 4146 130 ........ ........ ...... 5195 4312 135 ........ ........ ...... 5394 4477 140 ........ ........ ...... 5594 4643 145 ........ ........ ...... 5794 4809 150 ........ ........ ...... 5994 4975 155 ........ ........ ...... 6194 5141 160 ........ ........ ...... 6393 5306 (...) Gear Change RPM drop (change @6400) RPM drop (change @7000) ------------------------------------------------------------- 1 -> 2 -2314 (to 4086) -2531 (to 4469) 2 -> 3 -2237 (to 4163) -2447 (to 4553) 3 -> 4 -2046 (to 4354) -2238 (to 4762) 4 -> 5 -1088 (to 5312) -1190 (to 5810)
Modified by Johntomferg at 2:09 AM 4/23/2009
Modified by Johntomferg at 2:37 AM 4/23/2009
