Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Wed Jul 25, 2007 3:19 pm
I would send it back.
BTW, it isn't the rings in 2 and 3 I would on the worry about, but the outside cyls. Have you checked any of the basic internal engine tests? Leak down, coolant pressure check, oil temp, etc? Also, I would use Litmus paper to check the Oil's pH if at all possible.
