red boy »
https://forums.nicoclub.com/red-boy-u54887.html
Thu Aug 02, 2007 12:49 pm
I hope my engine turns out better. Its been 3 weeks since I droped my parts off to Mike at TOPHAT. Heres my list.
Alamo Auto Sports-arias pistons 20 over 8:8:1, rings,pins,and clips.AMS- sportman rods with arp bolts, the first ones they orded payed $540 i'm steel pissed
AMS- complete engine flelpro gasket setAMS- cometic head gasket. Can't use, tophat gets cometic to delete a hole that causes leaks. Useing that one.
AMS- clevite main and rod bearings, OEM thrust bearing. Clevite thrust bering have been nown to cause failyers.AMS-oil pump kit, can't use because it does't come with a front cover. Useing new complete pump with front cover.
Top Hat- timeing chain kitENJUKU RACING- arp head and main studs. The head will be torn apart checked, hot tanked new valve stem seals that came with gasket set. Three angle vavle job, cut completely around, not just at angles. The block will get the royal treatment also. And the rotateing assembly will be balanced. Thanks guyz for reading
Modified by red boy at 8:27 PM 8/2/2007
