Postby
727G35 »
https://forums.nicoclub.com/727g35-u290021.htmlMon Nov 04, 2019 7:22 pm
I'm going to a junkyard for a piece to electrically move my seat, I'd like to save time and money by getting a working part my first time.
I was wondering if theres somekind of tool like a voltage reader, except it puts power to the wires so you can hear if that specific electronic is starting.. I mean really I can use a 9v battery and wires right? I just was wondering if theres a name for a tool that does that
Postby
PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.htmlTue Nov 05, 2019 9:40 pm
Just bring a jump pack. Unhook the battery on the car (so it doesn't suck down the juice of your jump pack), and then connect your jump pack to the terminals on the harness. This should give power to the whole car.
Postby
MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.htmlTue Nov 05, 2019 10:11 pm
Yep, I have a couple portable battery chargers I use for this stuff. Make sure you take some good wire cutters and some decent gauge wire in case you can't get to the factory terminals. I had to pull a trunk lid from a Lincoln LS once. Battery (and terminals) are in the trunk. Folding seat releases also in the trunk. Trunk was closed, and I didn't have a way to cut the main harness or large-enough gauge wire for the kind of amperage involved, which would both have saved me a lot of trouble.
Postby
MinisterofDOOM »
Postby
727G35 »
https://forums.nicoclub.com/727g35-u290021.htmlFri Nov 08, 2019 11:29 pm
Awesome thanks for the advice I have a jump box I think it only gives power when cranking tho not sitting idle.
I took an old 18v ryobi battery connected terminals with alligator clips so if jump box dosent work I'll try that. Just figured they should have something like that already.
Postby
IanS »
https://forums.nicoclub.com/ians-u23642.htmlSun Nov 10, 2019 8:29 pm
Get yourself a Power probe.
WAY more useful than a multimeter when it comes to testing 12V stuff, and you can easily plug it into a jump pack and test any 12 device on the car if you know the wiring diagram. I actually own 2.
