assassin7420 »
https://forums.nicoclub.com/assassin7420-u72863.html
Thu Dec 11, 2008 3:26 am
In my S14 I won't leave home with out the following...
In the glove box,Assorted Wire CrimpsElectrical TapeDuct TapeAt least 3 Hose clamps for Intercooler piping3m double stick mounting squares12 Inch ¾ Socket extensionA set of Metric allen keysSmall 2x AA Mag-light with 3LED bulbAssorted Zip-Ties
In center consoleAm Pro ratcheting wrenches, In 10mm, 12mm, 13mm, 14mm, and 15mm.Stubby Wrenches, In 10mm, 12mm, 14mm, 16mm, and 17mm.Am Pro ¾ Socket wrenchDeep ¾ sockets, In 10mm to 17mm¾ Socket extensions in 3inch and 6 inchCraftsmen ¼ Driver with 8mm bit for Intercooler hose clampsCraftsmen Screwdriver with assorted bitsStanley Flathead and Phillips head screw driversCraftsmen Stubby screw drivers (flat and phillips head)Victorinox Swiss Tool Multi tool.Spark plug socket for SRNeedle nose pliersCouple of extra screws, nuts, and bolts.Spare fusesPen
And the OEM tire iron under the pass seat.
Couple of notes, People might knock on Am Pro tools but they have the same gears as gear wrench ratcheting wrenches, And FAR better gears then craftsmen socket wrenches. They also have life time warranty's. I have broken exhaust bolts with them and everything. Still in the same shape as the day I bought them.
Also, To keep the noise down in the center console I place 1 Microfiber rag under the tools, And 2 on top of them.
