dash »
https://forums.nicoclub.com/dash-u40408.html
Fri Jan 16, 2009 5:00 am
I believe Tomei hydraulic cams work out to ~$460 per pair usd.Very EZ to see if FRsport will deliver
In addition to a handful here got 'em in the past, check out sxoc project pages and you see people STILL getting new Tomei cams in the box.
xris from ns.com replaced his 270s with some 260 solids from Tomei not long ago. He said he ordered them, a few weeks later put down solid dyno numbers with his 20G
one off-build CA18 recently put down solid numbers with very impressive torque using a controversial chinese turbo. Owner told me he ran inexpensive CA18 256 degree/ 8.9 lift regrinds with stock springs to achieve that!
Two different profiles used in impressive starion SOHC 2L (non-us version), regrinds by the very same company. Based on the results, I'd try them in a heartbeat. If they're still available I'll definitely grab a CA18 pair to try out when I get the starion cams
So there is hope of alternative cams for the CA18. We shouldn't have to put up with this 'limited/no availability' bull**** ....NOR... should good proven cams be expensive. It is only a matter of someone taking the initiative to get the RIGHT company involved. Ask the DSM guys
