Grant@tirerack wrote:A) Like many tire companies. Kumho makes many different performance levels of tires from entry level to all out max performance tires.
B) Tires don't just blow out on their own. If you give us some specifics on the situation we could all make a more informed judgement. Odds are the tires were either over loaded or not the correct type of tire for the car's setup.
C) I would put the MX easily in the top three or four Max Performance tires I have tested for dry traction (and I have driven on every performance tire we sell both on the road and the track as part of my job). Check out our test results for the MX:
http://www.tirerack.com/a.jsp?...h.jsp
Saying a brand is 'crap' is a very broad brush stroke wouldn't you say? If you buy a entry level performance tire and expect it to perform well on a car tricked out with an advanced suspension you are going to get what you pay for. If you have never driven on the Ecsta MX, reserve your opinion until you have one based on experience. The Ecsta MX out performed both the AVS ES100 and the AVS Sport both on the skid pad and on the track. Yeah, if you put those two up against an Ecsta Supra 712 there would be no contest. It is what is is, an entry level performance tire.
Ok, Kumho's Ecsta MX's on a Subaru 2.5RS w/ Tein HR dampers, sways, etc.
This person is VERY anal about tire pressures and has them set to about 34 psi in the front, and 36 psi rear, warm. The car is full cornerweighted and aligned. Weighs all of ~ 2800lbs.
The tire had no bubbles or anything in it.. yet it blew out driving down a perfectly smooth road with the ambient temp about 50 degs. outside and him doing 45mph in a straight line.
These are not the tires he races on and the suspension is kept of full soft for the road. Yet the tire blew out. Not due to something on the road but ripped the tread off the sidewall.
Less than 2 months later... the same thing happened to a friends bone stock Z06 running the same tires.
And even then... month later a friends 300Z has the SAME thing happen to him while driving to Houston.
Now I've done a sustained 140mph sprint on the way to Houston for a good 2-3 miles, road raced down a local road 5 times in one night, and just gone balls to the wall with my Teins on my Falken's and I haven't had any illeffects whatsoever. Not to mention they have more grip than the MX ever will.
That's not a coincidence... that's poor quality.
