From
https://tiresize.com/calculator/, there is only a 0.9 inch height difference in those two sizes. Do you see 0.45 inches of clearance all around the circumference of the tire? When you turn lock to lock, do you see enough clearance? If so, it should fit. That is very little difference and I bet it wouldn't be a problem. I doubt the engineers cut it
that close. I went 0.3 inches taller but 0.4 inches narrower for my daughter's winter tires with no issue. But you need to check it out and make sure it will fit for yourself.
