Well, here are three contradicting opinions.mcrews wrote:They are very quite, and contrary to what was said in this post, they DO NOT "At 5K they are severely degraded. At 10K, they are shot unless you have a high tolerance for abuse."
In theory, you are correct. In practical application, it's not necessarily true. Rolling friction, weight, pressure fluctuation etc. This only applies during steady velocity. At such point that acceleration is introduced, it can be argued, that the longer torque arm actually requires more power due to it's higher moment of inertia.mcrews wrote:And actually, just using common logic and math would explain that a larger diameter, once in motion, reguires less energy to cover the same distance as a smaller diameter.
so yes, I got better mileage AND infact did factor in the size difference.
Just throwing it out there too.Tirerack wrote:the Kumho Ecsta ASX displayed abrupt break-away characteristics, making it feel unsettled and very slippery, especially when attempting to accelerate and during braking.
Look at the graphs closer - it says "Eagle F1All-Season." All the tires listed there are ultra-high performance all-season tires. Go onto the tire rack and read the full reviews for each one if you want. They're "ultra-high performance all-season" and "ultra-high performance all-season and low price." Same categories. Try looking a little closer next time.Unnatural1 wrote:The ratings graphs that were presented are not comparing apples to apples. You've got tire ratings for two different category of tires. The graph that includes the Eagle F1 is rating Max Performance Summer tires. Max Performance tires are the last stop before you get into the Competition tires. They are no holds barred performance street tires. You are then comparing them to Ultra Performance All Season tires. Wow, that's a fair comparison.
Tires degrade just sitting in air. They start structurally degrading upon use and continue from there. Why Michelin says all bets are off on tire ratings for any tire over 20K miles. One of the many reasons performance tires do not last 30K and have soft rubber compounds.mcrews wrote:I guess to wrap up this thread, blanket statements like "THEY DEGRADE AT 10K" serve no purpose in any conversation. especially when the blanket statement is not true.
OMG...Generals...another tire company I've had bad luck with.qship96 wrote:The marketing slogan "Sooner or later you'll own Generals" is aimed at those who currently own Kumblos, Hankooks, Nankings, Nexens and aspire to move up in the tire world!
damn brian,I wish I could twist facts like you....you change arguements like you change underwear.The point of your broad stroke statement was that ALL KOHMOS DEGRADE IN 10 K.maxnix wrote:Tires degrade just sitting in air. They start structurally degrading upon use and continue from there. Why Michelin says all bets are off on tire ratings for any tire over 20K miles. One of the many reasons performance tires do not last 30K and have soft rubber compounds.
Some people are curious to know that there are numbers larger than 2 that are not collectively called "many", but have individual names and values. There's another true blanket statement for you.
