Promised I'd update with pictures of cut off when I got the new housings. So I delivered. Also pictures of the spoiler painted to match the rest of the car. And a video of me killing my old tires by drifting around in a parking lot.
Fixed the glare issue by duct taping over the hole in the shield. Thinking these burn cooler and it wouldn't be a problem, guess I was wrong as you can see it melted through the duct tape by the time I made pics of the second housing set lol. BTW they are both USDM cut off housings but because of the glare shield on the HID's it keeps the light from shining low enough on the housing for it to even utilize the housing cut off... They must be angled slightly cause you can see the way they cut off. with the high beam hole in the shield blocked THIER IS NO GLARE WHATSOEVER. Need a solution for that better than chrome duct tape though...
First housing option... Low Beam
high Beam
Second housing option... notice the duct tape melted through on the passenger side lol. You can sort of start to see the USDM cut off line with the duct tape melted away haha.
High beam. Housings are identical, so no idea why the high beams look so different from left to right... wierd.
Second housings have a blue halo ring which really makes the blue sleepy eye mod pop.
Wangan wing all painted up.
I know... too much fender gap. I put new, smaller tires on today. I need to lower the car some more now.
On a side note.... This is why I had to put new tires on today HAHA. Nothing like drifting a abandoned parking lot to finish off a set of tires. Also was using the blue sleepy eye's to stay visible but avoid blinding the camera with HID's (camera was below the cut off line)
[youtube]
http://www.youtube.com/watch?v=Sk4w8xx6CtE[/youtube]
