damesta »
https://forums.nicoclub.com/damesta-u11482.html
Thu Feb 02, 2006 10:02 pm
Allright guys, got some more info, somebodys got to know somthing about this. Everything has been double checked, the pulley marks are accurate, the belt is on correctly, not off a tooth, have checked the cam timing and made sure everything lines up. My engine came straight from japan in very good condition, had timing service done by nissan there, still had the genuine nissan sticker over one of the cas bolts to show the timing hadn't been changed and its set at 10 degrees btdc and runs great. My crank pulley is accurate and the second mark lines up with tdc on the cam pullies. The funny thing is my crank pully has 6 marks like normal, all have the white paint except for the 0 and 10 degree marks which have the orange paint nissan usually uses on the 0 and 15 degree marks. Ive checked the a/f on the ecu in mode 1 and 2 and its good. I tried advancing it to 15 and it still ran fine but the cas is rotated almost all the way counter clockwise and there is no noticable hp gain, also, the a/f mixture in mode 1 and 2 are really off and showing that its leaning out.
So, it really seems like my CA is suppossed to be timed at 10 degrees. So this is weird, other people have had this specific problem as well and no one has come up with a good explanation, kinda go's hand in hand with all the people that have their cas' rotated almost totally counter clockwise to hit 15 degrees. The euro fsm clearly says 15 degrees but there are many resources online that say stock ignition timing is 10 degrees for the det and 15 for the de, those resources all come from japan, NZ, and Australia. After doing alot of searching a ran accross a couple things that say there is different information in different versions of the fsm and that the jdm(japanese language version) of the fsm says 10 degrees btdc is the factory ignition timing spec.
So, does anyone have any info on this? Have any of you guys with your cas rotated almost all the way counter clockwise checked your a/f mixture in mode 1 and 2? How did it check out?
