shannonk »
https://forums.nicoclub.com/shannonk-u84728.html
Tue Mar 18, 2008 12:26 pm
I just replaced the timing belt on my '87 Maxima. Instead of counting the teeth in the old belt between each of the three gears before I removed the old belt, I only lined up each gear with its timing mark, expecting that the alignment marks on the new belt were going to line up the timing marks on the gears. Well, they didn't, and when I put the new belt on, it was a half tooth off on one gear, probably because the new belt wasn't stretched yet. When I cranked the engine back up, my timing was off pretty bad, but adjusting the distributor fixed it, although I had to turn it almost to one extreme to get it. It still doesn't seem to run quite the same as before, and considering how much I had to adjust the distributor, I suspect I'm one tooth off on the belt and wish I had counted the belt teeth between the gears.Not sure if your problem is more major than this, but maybe this will help...
