slakker »
https://forums.nicoclub.com/slakker-u10544.html
Sun Feb 29, 2004 2:06 pm
Thank you Nistech. I am going to give that a try on wednesday. Being the bearing caps are what we are referring to, Is this the rod bearings or the crank bearings (the ones that hold the crank to the block). Is the only thing that I am checking for is a tear in the metal. Because Ive never seen them before I am assuming that the bearings are enclosed or atleast partially enclosed. If there is no tear on any of them then what else should I check for. Should I clean them? With What? Can they be cleaned? Hoping that they are all clean and untorn, What will my next step be? Thanks again
