newdude1 wrote:So even though my intake cam lines up perfectly with the black chain link and my exhaust cam is off by a tooth it doesnt matter?
Correct. As long as the dots on the cam gears are where they should be, your fine. The colored links on the chain are to aid in installing the chain.
newdude1 wrote:And how do you know you are one the compression stroke?
The valves will be closed, or you can use the hose from a compression tester and hold you finger over it. When the piston starts comming up, you will feel pressure blowing out of the hose.
