Timing? other problems? dont know
jej23
Car: 240sx, sr20 swap with extras
Thanks for the info, i already bought a new tps and i tested it and it seemed to check out really good, at this point in time the car wont even start cause its running so rich it just covers the plugs in fuel, so it could very well be the regulator, i have pulled the rail and checked for leaks and there were none from around the injectors or tips, so that leaves me with some variables to work out. Thanks for the help if you or anyone thinks of anything else let me know i really appreciate it.
S13FASTBACKSR
Car: '92 Fastback SR powered
this thread has gone on so long i cant even remember what we've checked and havent checked lol..we've checked the tps but not the fuel pump, injectors and fpr? i would get new spark plugs so the car will start and a new fpr because thats the cheapest. If that doesnt fix the problem then i would check the new spark plugs and see if any are blacker than the others..if one ore 2 are then that most likely means that spark plugs injector is sticking open too long or you can do what dori said to do with the injectors as far as testing them and did you test the fuel pump already? also did you ever run your ecu for codes?
jej23
Heres the run down......I have tested the tps it is now good, it has a new CAS, ignitor chip, fuel filter, the pump is a 255 and it is priming to the rail, I pulled the rail and watched the injectors they did not seem to be sticking open. ALSO I would check the ecu for codes but the little knob in the ecu does not stop it just keeps spinning, this is what led me to get a new ecu, thats basically what i have done. So if the fpr is the cheapest is there a cross reference like the SER or where do i pick one up.
S13FASTBACKSR
a lot of websites like heavythrottle have oem sr parts
harangatang
Car: 95' 240
S13FASTBACKSR wrote:well first of all you dont have to mess with the timing chain everytime you restab the CAS..you just restab it and thats it..also the dot closest to the dash should line up with the dash in the end..is that how you have it? you can also try turing it 180degrees maybe that will work for you like it did the other guy...if this doesnt solve it change your fpr
how can you turn it 180'? When u turn the cas 180, and try to plug the plug back on it, the plug gets stuck on the watercock. asking cause Im having some of the same problems..
silentvoice71
IMO its fuel related if it continues to run rich as hell we got good spark aparently timing good iavc good tps good. Id check FPR.
jej23
turning it 180 is only the rotor on the inside of the cas not the whole unit, pull the little plastic cover of and pull it out of the head a little and turn it 180.
jej23
Yes it has good spark on all cylinders, im not sure about the iac, i have a new one sittin here but it is not put in yet. I worried about the ecu, because i can not read codes off of it, the little screw that you have to turn well on mine it just keeps spinning it does not stop, and also not sure id the fpr is bad so ill have to look into getting another one of those.
S13FASTBACKSR
iirc it doesnt matter if the screw keeps turning..just turn it clockwise in one full rotation and stop it yourself..then back counter clockwise one full rotation and stop it yourself
harangatang
Car: 95' 240
jej23 wrote:turning it 180 is only the rotor on the inside of the cas not the whole unit, pull the little plastic cover of and pull it out of the head a little and turn it 180.
what do you mean by the "rotor"? the plate with all the degree marks on it? or the rotor itself?
jej23
When you pull off the cas cover you will see the wheel with the timing marks, if you undo the mounting bolts for the cas should be two 10mm, then the cas should slide out of the head, take a philips screw driver and the entire wheel and gear under the valve cover will spin together, make a mark so you know where bottom and top is and turn it 180 and see what that does, if nothing then turn it back and recheck timing.
jej23
Ok so here is an update on my piece not running, the ecu ground is pulling 75 ohms, and the eccs relays under the dash right by the computer are not clicking on or off, and ideas if this is just a bad ground since my battery is in the hatch????
cavakilla
Car: fast one
sound to me like you have a charge pipe leak... or a leak between maf and turbo...
silentvoice71
man dude your havin a fun time with this arnt you?
jej23
Yea its a great amount of fun LOL. the harness has now been ripped out and is now at wiring specialties. a new ecu is on the way. So now when the harness comes back this damn thing should run like a top.
silentvoice71
man if i get my motor in on time your commin up to help because your gonna be a swap pro after this haha.
jej23
Yea I will help anyone in anyway possible, i have been in and out of that car in more ways than i want to talk about. LOL. I've got to the point where pulling the turbo and manifold is a 10 min job. And im a pro at timing let me tell ya, only done it eleventeen times on my piece of crap.
FSUDrifter
Car: trying to decide on one...
figure anything out yet?
