timing help
mixeds14
Car: 240
like i said b/4:
u dont nessecerly have to let ur car sit until the gas evaporates, its actually a bad idea because (someone correct me if im wrong) but if its floded the gas will get down to your oil n u dont want that.
what i do, is take the fuse for the pump off so it dont send gas (its under the dash by the door) n take off all the sparkplugs n turn the engine till all the gas is out, u will see the gas comeout as it hits compression then just put new plugs n it shoul be fine.
run it until it dies that way the new plugs can burn all that its left, then put you fuel pump fuse back on n it should start.
Uberck
Car: 240sx
okay i will try that but at least does my timing sound like its matched up now?
mixeds14
Car: 240
look if u have douths about it just do a compression test, it shouls have around 150 give or take on each cylinder since the motor is cold if it was runing then it should be alot more.....
Xj220gt
Car: 1995 Nissan 240sx SE
well, if it didnt stay on, your timing is off. Since it turned on, your timing is close, but not there yet.swivel the distributor a bit.
my car did not stay on the first time or the second, but after swiveling the distributor a bit, it stayed on.
Uberck
Car: 240sx
im a newb swivel meaning just loosen the bolts that hold it on a bit and turn it a little?
Xj220gt
Yup.
Uberck
Car: 240sx
yup thats a no go a had my buddy holding the key and the starter is turning nothing from motor as i swivel it
Xj220gt
Its probably flooded again.....
because you did say it started before?
mixeds14
Car: 240
man i hope u aint using the same sparkplugs, what plugs are u using(part#)
