Xj220gt »
https://forums.nicoclub.com/xj220gt-u98826.html
Tue Mar 17, 2009 6:07 am
If the car is actually turning on and then shutting off:
- Check all the harness connections that you unplugged and plugged back in. - have someone start the car and push on the gas a bit to see if it stays on.- if not, swivel the alternator a bit until it does stay on.- try not to flood the engine, or it will definately not go on. - try not to kill your battery.
I had the same problem with my car after changing the timing chain. The problem was that I had not completely plugged in some plug and when I tried turning it on, it would not. the more I tried, the more I flooded the engine, so I had to wait for it to evaporate before I could try again after I had fully plugged in that plug.
ALso, how sure are you that you are at TDC and not BDC?
