elwesso wrote:This is the way I see about oil additives... There are a few (and I mean literally like 3) that I would use, and 2 of those are for right before an oil change......
If it was so good, why wouldnt they just put it in the oil to begin with.....? if it makes the oil "slicker" why wouldnt they put it in there..... Something cheap like that to increase lubrication qualities would be a no brainer for the oil companies..... IF IT didnt have some side effects on longevity, etc....
Pito, honestly I think that you should look inot a new engine... I would be ALL over the T3 swap...
pito11213 wrote:well the consensus is that the guides must be done to have that piece of mind.
I have the thought every time I think about slamming on the gas, just imagining what is going on in there.
So I dont. Fortunately the Q has enough power that I dont have to. Just let the car cruise on up to the speed.
One way - don't drive it until you can replace them. Budget for oil pan removal and have an oil pump cahin drive on hand.JT_MONEY_2004 wrote:OK, this is my 2nd Q, both 90's. Both were bought used and i have no idea weather or not the timing guides were replaced......This new one has about 73k on dash, but on the ride home from dealer i found out the odometer has a problem, it works sometimes, so the mileage isn't exactly accurate.
However, i'm sitting here today and thinking about the guides and how to circumvent or delay the problem.
pito11213 wrote:Maybe the people with 20's on dont even know about the guides, I didnt until I came to this forum.
