95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Sun Sep 10, 2006 3:20 pm
ok, first of all, the timing can break without warning at all, it can be at a start up or on a highway...... now when you started the car after the 2 hours, did it sound normal????, or did you hear alot of metal sounds.,..... if it sounded like metal hitting metal then the engine is gone.... if the timing belt breaks in the j, the valves might very well be damaged, however,the valves will tend to seat which means that the valves will close, to be more clear, the valves will tend to go as far away as possible from the pistons, but not in any way assuring that all the vavles were seated, some people are lucky, and some are not......
the only way to check the timing belt, is to open the timing belt covers on each side of the engine, if you see a belt in there, and you can feel that it is tensioned, and you cant push it or pull it out.... then there is nothing wrong with it.the driver side timing belt cover can be removed the easiest, try doing that
