Sorry Escort 1.8L is the same as the Miata 1.8L which is also a Non-Interference. But good Story.dash wrote:16V 4AG is non interference. Broken belt won't bend valves Popped a belt on my escort 1.8L dohc motor. Changed the belt in minutes literally & back on the road. Motor ran with a light miss and lifter tap = minor bent valve suspected. At the end of the day, motor smoothed right out/lifter tap gone. I supposed the slightly bent valve straightened its 'cocked' head itself as it continuously beat on the seat. lol Ran perfect ever after. whew... that was a close one
na, the best way to describe the sound, is like there was no fuel getting to the motor. At first i thought my fuel pump went.ca18det240hatch wrote:Well did you hear anything hitting while you were turning it over? You may be lucky and your cams were in a neutral position when it broke.
you shuld burn for sugesting Lucas oil treatmentfrosti108 wrote:just add some lucas youll be fine
Na, I still have to buy a belt. Im getting it tomorrow afternoonthemadscientist wrote:So it's back together and won't start?
$32?? ones on autozone are like $13 -25ch187 wrote:thanks for reminding me. mine just arrived at nissan. $32 aint bad.
Oh nicech187 wrote:id rather buy parts from the dealer. i have an account with them so i get a baller discount also.. pulsar ca18de one will work
lol... interesting. Didn't know what caused the miss/lifter tap then. Never did it before or any time after.Dunno the BP like a ca18 or 4agdriftin8ez wrote:
Im pretty confident i lined the marks correctly, I counted the number of "cogs" on the belt. And according to the mad scientistDattebayo wrote:You probably forgot to align the timing marks before putting on the belt. You did crank it a bunch of times after it broke, you know...
So you know............................themadscientist wrote:You would not have damaged it further by cranking after the break, what was going to happen had already happened.
