Timing belt broke. Am I screwed?
ilovecoupes
Dattebayo wrote:I'm sorry, I was referring to the head timing matching the belt marks. I have had issues with a similar motor (Pulsar) when it sounded like what you were describing. Re-alignment worked for me, but I can be mistaken for your issue right there... (especially when it comes to TMS's experience)
ya I guess ill triple check it, just for fun. But im 90% sure the valves are bent.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
On the bright side, its not the most expensive thing that could have happened. My machine shop rebuilt my head and it only ran me about $300 to clean up the mating surface, put in new everything (except valves), and replace a few slightly bent valves. they quoted me something like $8/valve, so most you would be looking at would be somewhere in the low $400s for basically a brand new head. or you could just go get another head, slap it on, and go.
ilovecoupes
r34 gtr wrote:On the bright side, its not the most expensive thing that could have happened. My machine shop rebuilt my head and it only ran me about $300 to clean up the mating surface, put in new everything (except valves), and replace a few slightly bent valves. they quoted me something like $8/valve, so most you would be looking at would be somewhere in the low $400s for basically a brand new head. or you could just go get another head, slap it on, and go.
ya that is what im debating on right now. I have to call a machine shop tomorrow and get qoute, on new valves and valve seals. But I did find a guy selling a head in WI, he rebuilt himself for like 180+shipping.
so well see.Also did a compression test. I got around 50psi on all cylinders. Did it on a cold engine, and I had the throttle body opened.
themadscientist
50!? 50!?Yeah something is jacked up. My engine has a blown head gasket and manages 60.
r34 gtr
yeah man, its toast. lets see some pictures of the carnage when you pull the head...because youre gonna have to.
Masterdebater
Car: 1989 nissan 240sx coupe
so the pistons hitting the valves wouldnt damage the pistons as well as the valves?
boost_boy
Intake valves are the first to get yoked-out!
Dee
frosti108
Car: rb s13 coupe
dude seriously. if u had some lucas in there like I TOLD YOU,,, you would be doin mega mad tyte JDM drifting rite now but noooooo
:D
ilovecoupes
themadscientist wrote:50!? 50!? Yeah something is jacked up. My engine has a blown head gasket and manages 60.
ya it may be a little higher, but it was my first time ever doing a compression test. And I did it by myself, and the engine was cold, so the numbers are probably a little higher. Also I broke the nose off my CAS, so timing probably wasn't completely on.
And I'm really interested to see the destruction too.
And Lucas additive is for heros
r34 gtr
I only use lucas when something goes horribly awry, but the car still runs. OH CRAP I RAN IT OUT OF OIL!!!!! ker-Lucas. Or the classic, "Oh jesus I overheated it! The block is SMOKING!" you had better believe I used it then.
frosti108
Car: rb s13 coupe
next to lucas, oil is the actual additive...
i always run atleast 65% lucas in all applications including my morning wheaties and laundry detergent. oops sorry, only 35% in my shampoo
mdubc405
Car: white 1989 240sx coupe w/ca18det(t3/t4 .50trim)
i would also like to see pics of the carnage
ilovecoupes
quick question, can i take the intake manifold off, with the head. Or do i have to break the two apart, to take the head off??
ca18det240hatch
you can take the head off with the intake manifold attached, youll just need to get at the hoses under the intake manifold which is harder with it on.
ilovecoupes
THREAD REVIVAL!!!!!!
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
Hey, i broke my belt too! im jsut saying to hell with my det head and im gonna rebuild my de head. My pistons have loverly little dents in them
