That is the most origional description I've ever heard and its great! and to comment on this.."Has anyone actually ever had a knock problem on a N/A KA?Just curious, I've bumped my timing up a bit (~26) and have had no knock issues regardless of outside temp or gas octane."Nismo1182 wrote:Ive had mine bumped to 25*
Watch out for detonation. It sounds like BB's in an empty 12oz soda can.
So you just said my motor is clean and functioning properly is the reason......K, I'll accept that.DjPantsSpecR wrote:it can actually be a lot of things. Like was previously said someone was runing 30 with no problems. A tired fuel pump or nasty fuel system can cause lean or knocking conditions especially under timing advance. also a nasty motor with lots of carbon buildup is always more likely to knock due to the hotspots
I used to run a ****-ton. Ive never put a timing light on my motor, because i set it by the timing marks and then just eyeball my advance.
recently i knocked back my timing to about 20 degrees because i wanted to complement the low end of my 240/232 cams, but with 248/232 that advance is invaluable
ive never heard my 240 knock and i used to have a lot of advance. ive heard knock many times on my fathers lincoln and it does sound just like a can full of BBs.
89 octane is more than likely sufficient on your stock compression engine on any reasonable amount of timing advance. i wouldnt go any futher than about 28 degrees though. timing is no big deal, its nice to shift the powerband to your liking and its hard to mess up these KAs by detonation
If you are using the stock ecu tune your advancement is much too far, and it probably has raised your exhaust temprature too as well.If you are on a stock ecu tune I don't see why you would want to advance more than 5 degrees at the most. Some guy's get risky and go for a total of 8degrees, but they are also using expensive NGK iridium sparkplugs to prevent detonation. Teh only way that you can safely advance any further is by changing the actual ignition, and fuel maps of the ecu. Technically the further you advance the more fuel that would be needed to somewhat cool the cylinder charge. This probably means that you will need increased injector size as well as an ecu tune. Advancing the timing also icreases scavanging as exhaust temprature rises.burnin240sx wrote:I know timing is supose to be set at 20 btdc. but i want to bump it up a little for some free ponies. I currntly have it at 30 btdc and it improved my 1/8th mile time. so what is the max I should do this to beside's the ovious until advance slows the et time.
Is there any thing I should watch out for?
On the case of increaing injector size instead of bigger injectors ,is it possible to just increase FP with an adjustable FPR or to use an SAFC to increase the duty cycle. Would this suffice for someone who would want to advance say to 25+BTDC or more. Also heres a chart I found on T-I that show the melting point of spark plugs and it supplements why iridium plugs help when you want to advance timing and to prevent detonation Zinc == 420Aluminum == 660Copper == 1083Steel == 1400-1500Platinum == 1772Iridium == 2410Bigvinnie wrote:
If you buy a Digital Timing light indicator for $95.00, then you don't need to use the crank pulley for refrence.Digital is the way to go less hassle, IMO.....:: orion :: wrote:1) Buy timing light, $45
3) Using the light, check the marks on the crank pulley. They are ( -5, 0, +5, +10, +15, +20)...
The initial problem is in the ecu ignition timing more than anything. If you think about it as your RPMS increase so does ignition timing as well. At idle it may run at 20ATDC, but it will increase to something way above 40ATDC. I never really seen how changing ignition timing at the distributor can make a significant difference accept for the gap time between rotor, and ecu ignition spark is brought closer, making the spark stronger in less gap time (probably why you see like 3~5HP gains on dyno charts).Ultimately the real problem is in advancing the distributor to far to where the engine isn't very streetable at idle as it is brought further from it's proper location at 20BTDC. How you calculate an increase to injection to suffice for an increased timing I have no idea where that came from ( you need to change the actual ignition maps and fuel maps to stay more consistant, cam position also has alot to do with the amount of play you get with your ignition timing).KA24de stock ecu tunes increase fuel (HC's) levels as timing advancement is increased to deaden a hot cylinder charge from preventing knock so there is already to much fuel being used. Where it gets dangerous is when you would want to actually decrease pulse width on the stock tune, for the overcompensated fuel that is being used on the hot cylinder charge.Shrinking the pulse width is more accelerative to jumping the ecu ignition timing it just becomes more dangerous as the EGT is increased. This more to where you would probably want to use iridium plugs instead of something like platinum.I don't quite understand your question as far as injector size or bigger injectors? Sounds the same to me....3dKa24 wrote:On the case of increaing injector size instead of bigger injectors ,is it possible to just increase FP with an adjustable FPR or to use an SAFC to increase the duty cycle. Would this suffice for someone who would want to advance say to 25+BTDC or more.
