EazyBreazy »
https://forums.nicoclub.com/eazybreazy-u10672.html
Mon Apr 07, 2008 9:36 am
Quick tip for when/if you get a fender roller and do it yourself.
1. Use a heat gun to make it easier to pull the actual metal out, but also makes the paint more elastic and less likely to crack or peel2. Go slowly, pulling only a little at a time in the rear to prevent caving in the quarter panel.3. keep the tire/wheel close keep putting it on and off to make sure you dont pull to far. It looks dumb when you do. (see my sig lol)4. take your time5. Make sure that all debris on top of the fender lip inside the wheel well is removed, believe me it can and will stick there, and it will ruin your fender.6. TAKE YOUR TIME the more careful you are the better your results will be.
