Alright.Lets get started.Go find a measuring tape.Got it?(assuming you have a 240)Go out side and measure your wheelbase from tire to tire or hub to hub.Then you will no longer be confused.musashin wrote:im still not getting it, apparently.
say a wheel that is the same size front and back, with tires the same size front and back.the front of the car is narrower than the back, which leaves less room under the fenders for the wheels. therefore, the wheels stick out more in the front.
am i still missing something?
I'm with you. There is less space from hub to fender in the front than there is in the back right? So if front and back wheels are same size, the front wheels should stick out more. I'm guessing the OP is rocking spacers or staggered wheels w/o knowing it. He did sound unsure of the offset.musashin wrote:i have the feeling were arguing different points here. im out. sorry for the threadjack.
silviasliderNJ wrote:i think the wheels are Elite's 17x9 +15
idahotuner wrote:
the wheel base is narrower. in the front then the back
and wider in the back that is why the wheels stick out more.
did you have to use spacers or did they clear stock struts?idahotuner wrote:got my elites mounted tuesday. 275/40 back 235/40 frontonly a roll on front and back for me. i liek the wheels sticking out for the hot rod look.
haha one one of my accord with my old wheels off my 240
these wheels will be going on my dd and just found some skunk2 springs for at the junkyard for $60.these are the wheels i just got for my weekend car,work rezax 17x8+5 and 17x9+5.musashin wrote:Everything clears perfectly. 17x9 +15 clears fronts by about 7mm. Rears are clear all over the place.
However, you should definitely have something to lower your car before you get wheels like these. And something for camber adjustment. Unless, it will look like
Nope, no spacer fits good.bobbyhill wrote:did you have to use spacers or did they clear stock struts?
if that directed at me you should be able to tell min is up on jack stands. i am waiting for my BPM coils and rucas to come. which i hear landed in cali this week.musashin wrote:However, you should definitely have something to lower your car before you get wheels like these. And something for camber adjustment. Unless, it will look like
You bet i willwhite90esex wrote:you better get some pics once its all together.
ok cool coolmusashin wrote:None of that was aimed at you. All to bobbyhill. No worries.
ohhhhh! ive seen these on an S14 and they look f*** cool! are these for the S13 HB? looks more liek a coupe piece to me... what are these things called?silviasliderNJ wrote:
Mine is the same, the fronts stick out more then the rear. Same setup for me Rota P45R 17x9 all around with 225/45/17 up front and 235/45/17 in the rear. No roll or pull.95zenki man wrote:Maybe my cars just weird but i have 17x9 +12 with 225-40-17s all the way around and they defantly stick out more in the front.. Its not much (7-10mm each side) but it is clearly wider in the front then the rear.
