alphapig wrote:Are you somehow able to adjust the camber from the engine bay?
Not quite... i just jacked up the car and pulled the coilovers down so that i could reach up to the camber plates.
andyhenault wrote:Unless you plan on wearing out a set of tires in about half the time, I wouldn't go adjusting the camber just for looks. It will also make your car handle terribly.
actually it did quite the opposite. i'm running at most -1 degrees. because before i was running with at close to zero or positive. and the car handles so much better now instead of hopping around turns like most front wheel drive cars i've driven in have it corners like it's nobody's buisness. But now i need another alignment to make sure that everything is in spec and not terribly off lol.
