audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Fri May 25, 2007 9:53 am
Man, my luck SUX
ok...Went yesterday for the install. I did not have my hex-key for removing the lock lugs but Nissan (who lost the key in the first place) had been able to get them off before. The tire shop could not get them off without destroying the rims. So, I went home and tried finding my lock set information and that was a no-go as well. Called the shop I got them from and they said to come by to see if one of their spare keys fit. If not, I was SOL
Wonderful
Today, drive way out there and I got lucky, they had one that fit. $10 later I was on my way back to the tire shop. My luck has changed!!!
or has it....
Tire shop pulls the car in. I wait. Looks like the key works. GREAT!!!I sit down and pop open a magazine. Time passes and the guy working on my car tells the counter guy my rims don't fit
So, I go out there and sure enough, the G rims I have do not fit the Maxima hub. I'm like WTF???? A call to Greg (AZhitman) confirmed that Nissan/Infiniti use standard hubs across 99% of their products so the damn rims have the wrong hub-centric opening cut. So, after calls to the OEM wheel provider I have the new tires put on the old rims.
I learned the following:1. Car does not have a shimmy anymore with the new tires2. Car is quiet as hell now (no more horrible road noise)3. Rims are actually not warped, problem was tires all along4. One of the rears was about to blow anyway
As far as the G35 rims, I am waiting for the OEM to call me back. Seems the hub-centric opening is around 63mm instead of 66.1 that it should be (they actually verified the size should be 66.1 as well). What they are trying to do is track down a local shop that can fix them for me at their expense, which is fine. The tire shop will charge me relatively little for the swap since I am a long time customer.
So, I have new tires and found out my current rims are not bent. BUT, I still have them on instead of the G rims. Wonder what the next little bad-luck issue is going to be.....
