If the head is off, there is no reason NOT to upgrade to a metal HG. Especially with how inexpensive the cometics are. Now if it were between a stock $30 head gasket and a Tomei $220 head gasket, there may be some room for argument. But $100 is hardly expensive as far as metal headgaskets go.JDMSIL80 wrote:I should have stated in my first post, my mods are:
Power FC, FMIC, 444cc, GT28R, turbo manifold, 3" turbo-back, Blitz EBC, Z32 MAF, HKS filter.
Going to install soon: Cometic HG, ARP head studs.
Planning to buy in the future: Tomei 256 Pon Cams.
Lastly, my power goal is 350whp. Am I looking in the right direction?
Oh really? What negative did you hear? Probably from people who didnt get their head and block resurfaced when it was put on. MLS gaskets need a 99.9999% perfect mating surface. That goes for all MLS gaskets, not just cometic.srdrps13 wrote:ive heard a lot of negative things about the cometic headgasket.. i ordered one and canceled it... i say go the extra step and get something a little more expensive that will last with no question.. greddy, apexi, tomei HG...and would 444cc injectors push 350? i doubt it...
I would safely assume around 75-85 ft/lb of torque less the sequence called for by the factory FSM whioch means no need to tighten loosen, semi-tighten, then completely tighten.JDMSIL80 wrote:With Cometic HG and ARP head studs, what would the torque spec be?
Same as factory or something different?
Thanks for the clarification, this route definatly seems to be the right one for me, and alot cheaper becuase i never knew you had to resurface the block too.boost_boy wrote: You know guys, the talk about headgaskets have been beat till death on numerous postings. A metal h/g is indeed a good buy if you have had your block decked and head resurfaced from a machine shop with really good machines. For those of you who are budgeted, are not interested in removing your blocks and are not chasing 400-500whp, i'd suggest doing something that myself, float6969, and possibly a few others have done. If you are just removing your head for servicing purposes and/or doing a light refreshening of your engine, then may I suggest this:
1. Get a stock headgasket
2. Go buy you a can of copper spray
3. Get you a set of fresh stock headbolts
4. Spray 3 nice coats of copper spray on that stock headgasket
5. Install headgasket using FSM or a manual designated for assembly of CA DOHC engines.
I can assure you of this, it will hold-up just as good as any cometic, greddy, hks or whatever MLS gasket under normal to above normal useage. If one cares to believe this, I'm using a re-used, cleaned with brake parts cleaner, dried with paper towels, sprayed with copper spray, and secured with ARP hardware headgasket and I run a wicked 15-20psi on pump gas. Gasket's holding up just fine and so is my engine.
Dee
Clean-up on aisle 18 and keep on keep'n-on. If you didn't understand that, then the answer is "Yes".........originalsin wrote:if i just do a stock hg replacement for a little refresh, can i just clean the block up with a scraped and maybe some emery cloth? and then should i take the head and get it machined or just do the same process as on the block?
My head and block were surfaced with a CBN cutter. I don't care if I am "ignorant", I am running a cometic anyway.Not_a_sr wrote:Dee, no matter how many times we all say it noone is going to listen, just dont get it myself either...
Stock headgasket = a fuse. make a 30$ part your fuse instead of your pistons and rings, 400Hp should be attainable reliably on stock headgaskets, its all in the tuning and fuel management!!!!
and for that metal gasket you probably need the block and head resurfaced by the Machine shop, which means pulling the motor out completely...
If it's not blown or smoking, clean it up yourself and keep going.originalsin wrote:yes to wat, cleaning the head myself or getting it machined
Hey man, I wouldn't put it out there if I too didn't do it myself. I'm no better than anyone else around here, but I've probably blasted more engines hands down . I totally entrust in the stock headgasket and copper spray set-up as well and just reitterating it as cheap/reliable option that actually works for those who are not willing to pull there motors, tear them apart, get the head and block resurfaced just to house a metal headgasket!2BN_S13 wrote:lol @ dee's earlier post...
So, cheap gasket from courtesy nissan (or other source yet to be named), copper spray (from where again?) and BAM good low HP application gasket? I could have sworn the thread about that a long time ago was just a joke! No F*in kidding...
Jon, if our members don't grasp this excellent concept, then most won't even be mediocre in their quests. It's not the boost that kills engine, but the sub-standard computer systems most live by thinking they can run big boost on an 8 bit factory system. Fuel+management+tuning= Fun on a stock headgasket.Not_a_sr wrote:Dee, no matter how many times we all say it noone is going to listen, just dont get it myself either...
who sells compcam valve springs and crower retainres for the ca18 and how much are they?csudhoff wrote:Just stick with the cometic, do some looking around though...you should be able to pick one up for around 90.00 the HKS, apexi, tomei ones are nice but i've never had a problem with a cometic gasket, not to mention its a 1/3 of the price.
ARP head studs are a good idea as well, i am not sure if you are looking to do valvetrain right now but i would consider doing CompCams valve springs and Crower Ti Retainers wouldn't be a bad idea either. They are best bang for the buck. Cams wouldn't hurt as well as manifolds but that all comes down to budget and your goals for the car.
$51.48 for a Fel-Pro from Advance Auto Parts.2BN_S13 wrote:Where in the world did you find a $30 stock gasket? The parts store is asking for $125, and other sites close...
