Blah blah blah...2BN_S13 wrote:Hardly $30, almost twice.
/point
You almost had me there.
It was closer to $30 than your $125. And for the record, I was trying to melodramatize it...
/point
I think that was me... 5th post in this thread.2BN_S13 wrote:Not you. The other guy who said it was $30 first...
WRONG, it doesn't say they need replacing anywhere in the FSM, they are NOT stretch boltstop_secret wrote:also to the last guy posting, the factory headstuds are designed to stretch when you torque them properly (torque, untorque, retorque) so they should always be replaced.
I'm referring more to the standard ecu with standard mapping as opposed to custom mapping. Custom mapping should be done by professionals and the only one to my knowledge on this side of the big pond is Jim Wolf Technology. Custom mapping is like programming a standalone because you've crunched the #s into the ecu. Standard mapping and big turbocharger, stock injectors and AFM+13psi is a reciped for a burned headgasket.sideways danny wrote:
Dee - I disagree with you saying the 8-bit ECU is to blame with the std gasket not lasting for big power, with a GOOD custom map the ecu is hugely capable. blame the mapping not the ECU
Scott Avoy in Tampa is a Nissan ECU guru. He does custom maps on SRs, KAs, CAs, RBs, and can tune just about any standalone you throw at him including Haltech, AEM, Microtech, SDS, etc...boost_boy wrote:Custom mapping should be done by professionals and the only one to my knowledge on this side of the big pond is Jim Wolf Technology.
