Kompresshun »
https://forums.nicoclub.com/kompresshun-u133574.html
Fri Dec 28, 2012 5:58 am
Glad to hear Jesda!
I'm still very pleased with mine overall - I just rolled over 130k miles last week. I've driven the car back and forth to Louisville numerous times now and it is honestly the best car i've ever taken on a trip. It swallows up luggage like an SUV and still averages 28-30mpg on the highway. It's a very solid, well built vehicle for the money and even at 130k, it has no major signs of wear aside from some minor cracking in the drivers seat leather.
Another big thing for me is the comfort too - it's honestly the most all around comfortable car i've owned so far. Now i've driven more comfortable vehicles, but most of those have been a bit too "floaty" for my taste. This car still feels connected to the road, but after a whole day of driving I don't feel fatigued or uncomfortable at all.
The only drawback to the vehicle is the lack of support for them. They were only made for two years(2005-2007) and while the 2008+ Taurus shares similar parts, the support just isn't really there for them. Some things i've learned from research and ownership so far:
1 - Avoid the CVT at all costs. The 6spd auto is the way to go, but service it regularly. Both transmissions had issues, but the 6spd auto was more solid and cheaper to repair if it breaks. Usually one replacement will last you for the rest of the life of the car.
2. The Throttle Body Control motor is an issue on these cars. You'll get a check engine light for it when it's going out, but don't hold off too long on replacing it. If you do and it fails, it will scare the crap out of you when it does. The vehicle will lose the ability to accelerate, but will continue to run. If it does happen, you can pull over for a few minutes and it will reset itself so you can continue on again, but it will only last a few miles. This part is easy to replace, but costs anywhere from $400-$800 to purchase depending if you go with OEM or aftermarket. I didn't have to buy this thankfully, the dealership I bought it from footed the bill. Usually one replacement is all you'll ever have to worry about, since Ford improved the replacement part.
3. Top torque rod mount - This is a $250 part at the dealership and has no aftermarket option. Thankfully with a little research I also found that a 98 Volvo S70 motor mount will work as a replacement for the bushing in the mount. You simply clean out the loose and broken pieces, then press in the Volvo mount with a rubber mallet or create your own press with a large C-clamp. This part costs $6-$20 depending on where you purchase it and works like a charm.
4. Puddle Lamps - These are located under the mirrors and were on option on the SEL model, then were usually standard on the Limited. They're little LED lamps on a circuit board inside the mirror and tend to fail from moisture. I'm currently working on a modification for this, because it costs $60-$70 for a replacement and that's rather high for a simple LED light on a circuit board.
Other than that, there aren't many other issues they have. They were a great all around car that people seem to forget about because of their bland styling and short production run. Between our Lexington branch and Louisville branch, 4 of us own them and the other 3 all have over 200k miles on them. One is nearing 300k and is still solid as a rock, with the only major repair being a transmission around 100k miles.
