http://scirocco.dyndns.org/faq....html
brakes do not stop your car, your tires ability to resist force does. if you spend tons of money upgradeing your brakes without having the tire traction to back it up, it is useless.
also, people upgrade brakes(those of us who know enough about it..) for the decreased heat fade/increased heat dissipation..
THIS IS ONLY A CONCERN WHEN YOU ARE HAVING A PROBLEM WITH THE STOCK BRAKES! IF YOU CAN LOCK YOUR TIRES UP WITHOUT FADE ON THE STOCK SETUP, YOU DONT NEED THE UPGRADE!!!!!!!!!!!! it will only net you MORE unsprung weight(yes, even with the Z32 alluminum calipers, they're still[rotor and caliper] a good bit heavier than stockers) more expensive pads and a higher bill.
seriously upgrade the pad first, to a pad that has consistent friction properties(fade resistance, so to speak), some SS lines(decrease compliance) and some good brake fuild, then tell me you need larger brakes...
almost no one ever does.
also, the "mnore area for more torque" brakeing thing is great..until you realise the maximum ammount of braking force you can apply with ANY system is goverend by the tires, and if you can lock the tires..well...you've obviously got enough clamping/braking force.
next brake thread I read about this crap gets deleted.-chet
