You are right on that.Chrispy300 wrote:AFAIK the VH doesn't have a AAC (acessory air control), it has a IACV (idle air control valve).
I own a laptop Consult, is there anything I should look at inparticular?Chrispy300 wrote:Have you had a chance to hook up consult?
Hopefully BG Quick clean will fix that on the first time (I have my fingers crossed).Chrispy300 wrote:Probably HLA's.
No vacuum leaks.Chrispy300 wrote:If you have a low idle speed then I would be looking at vac leaks, incorrectly set TPS, faulty or incorrectly set IACV or a dead wax expansion cold idle control in the throttle.
qsiguy wrote:Why don't you try tweaking the IACV while the engine is running (or not) to get it dialed in where you want it? I had to do that after doing my plenum job and cleaning the IACV. I don't know how many turns mine is set at but does it matter?
Q45tech wrote:Was the engine sent back to Japan or did some incompetent dealer tech do the work.
I know it would be almost impossible to meet new rings specs on a worn engine. Just the honing of cylinders, bearing [selection] etc could not be done at any dealership I know of.
I have a friend who builds race engines that run $35,000> $60,000 each he took one look at some heads and crank I sent him and he said no thanks and he has every precision system machine known to man.
Every engine we have re-ringed, rebearinged, new pistons never was quite perfect again. They didn't blow up for years but not oem perfect.
Even though the optional +- parts are listed in FSM Impossible to get them outside the Japanese factory.
You obviously have some sort of bias. Not all dealership techs are incompetent, there are plenty out there capable of doing a proper rebuild.Q45tech wrote:Was the engine sent back to Japan or did some incompetent dealer tech do the work.
Every engine we have reringed, rebearinged, new pistons never was quite perfect again. They didn't blow up for years but not oem perfect.
This is at the top of my list.qship96 wrote:I would be VERY concerned why the{LOW} oil pressure lamp stays on for up to 2 seconds at startup......even at 234K miles, mine goes "off" instantly as car starts, even in freezing weather cold startups
that might stay on a touch longer than my Q does but I dont think its anything to be alarmed about.Paul Wall wrote:
But there is a video of what I am talking about: http://www.youtube.com/watch?v=4PUaaxBR6s0
Running compression is quite a bit different from cranking compression. Nissan's cranking compression specs are give at open throttle, warm. If you have ever checked, cranking compression is a far cry from running compression if checked properly, they cover different failures/issues.Q45tech wrote:If you think about it a 14 psi variance is pretty tight spec ~ 10% of running compression so if one cylinder were down 3-4 lb/ft from it's 37.5 peak.
Q45tech wrote:We never seen problems at even 450,000 miles as long as the oil was changed every 90 days.BG Quick clean for Engines is designed to clean the oil/lifters- HLA/lower rings of varnish which must be drained 15 miles after it gets hot at idle [under 2000 rpm].
Do an oil + filter change refill with $1 oil + BG cleaner, then idle to 176F then increase rpm to 2,000 for 3-5 minutes, then drain change filter and put in new good oil + filter. This works 90% of time if not repeat the same proceedure immediately.
Oil + filters are cheap compared to the labor of just changing 1 HLA.
The fit is so precise that you often need to strip the head and oven heat and do the work while head is 200F in an oil bath......not pretty.
Oil level is always good but I really do need to do a oil pressure test because that will rule out a lot.speedeast wrote:This is an oil issue. Either you are low, which I assume you checked the dipstick, or oil is not getting "pumped" where it needs to be.
I change it every 3000 miles but mostly sooner than that, I can't vouch for the previous owner though. The engine was rebuilt like I said and this all started over night really. And I use 10W-30 but I may switch to 0W-30 or 40.speedeast wrote:it's pretty damn cold here, so you should be running a 10-30 or thinner oil. If you haven't changed it in a while, I would do that. Oil pumps in these cars are good, but don't last forever.
It is rare according to Q45tech that a VH45DE will need a oil pump replaced, I think T3 only changed ONE out and that was due to SEVERE NEGLECT.speedeast wrote:Not reaching 6900 rpms CAN be directly linked to an oil issue, especially a low or low pressure oil issue. You may need a new oil pump, don't rule that out... but I would measure the oil pressure somehow and get it off your conscience.
That is much better than the old fashion ones you would find at harbor freight for a couple of bucks.Q45tech wrote:Running compression is checked with an expensive metal washer like sensor that fits between spark plug and head with wires that run along side and out the coil assembly.
My old fashioned sensors have been replaced with fiber optic units for less problems with spark pickup:http://www.optrand.com/fliers/calplug_060201.pdf
http://www.piezocryst.com/pressure_sensors.php
Many 2007+ vehicles actually have special systems that use spark plug ionization to measure the after firing pressures.http://delphi.com/manufacturer...nized/
These can easily be adapted to Q45 coils and a standalone separate computer for logging.
Nope just rustyChrispy300 wrote:No big dents in the bottom of the sump?
Well at $8/qt that seems like a lot, what about Mobil One 0W-30?qship96 wrote:Just once, spend the coin and put Mobil ow-40 in it and see if it helps cure the issue- you can run that oil for 6000 miles to help offset the price if you want to, it can EASILY go the distance.
