Ticking and clicking from engine
unknown007
Car: White 1993 Q45 (G50)
So you all know of my ticking noise that has been bugging me.When I pop my head under the car I hear it clearer and here a loud clicking.My guess is nothing.Any help?Will try get a video up soon thanks.By the way could it have been a pine cone I ran over?
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
valves?
unknown007
You think?it's on the passenger side mostly.Would they be stuck?
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
unknown007 wrote:You think?it's on the passenger side mostly.Would they be stuck?
Sometimes pinhole exhaust leaks can do crazy things to your ears...
unknown007
The ticking and clicking has been going on for a while now before I lowered the car.I just heard it more when I went to check if the Pine did anything.
PyR0NiAk
i still say valves... how many miles on the engine?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Do you mean HLA's?
I think it could be either exhaust or injector problems.
unknown007
Injectors?Again?Can't be.It's sounds clear from underneath.125k very close to 126k.I did a plenum job at 123k.I checked again today and it was smooth but can hear it like always when I drive.This car is making me angry.
PyR0NiAk
yes my bad... and forgive my ignorance but how could injectors make a clicking noise?
unknown007
They do but according to my teacher he said not that loud.Someone said it could be valves or something since the car was sitting for like 1.5 month or something before I finally got it all together.Eh?I'm annoyed.
qship96
Car: 1996 Infiniti Q45
It is probobly just the rods knocking on the block trying to come out to play.
Modified by qship96 at 9:33 PM 5/2/2009
unknown007
qship96 wrote:It is probobly juat the rods knocking on the block trying to come out to play.
Doubt it.A rod knock would shake the car up.
Infinitiguy19
Its not rod knock unless your ran the car with bad or low oil.
But does your car shake even a tiny bit?
PyR0NiAk
try changing your oil and adding slick 50 oil treatment...
unknown007
The car does shake like a tiny bit.Like when you get into a muscle car with straight pipes.Not straight pipes from headers with no muffler but has cats and all.Eh I have had a couple mis fires like two.Maybe they're my KS.
Infinitiguy19
If it shakes then its slightly missing, call me so you can tell me further.
goody90q45
Car: 1992 Infiniti Q45 (sold)
unknown007 wrote:So you all know of my ticking noise that has been bugging me.When I pop my head under the car I hear it clearer and here a loud clicking......
Hydraulic lifter (HLA). It's time to try the Marvel Mystery Oil treatment.......and 2 bottles of Redline Injector Cleaner in a full tank of gas.
unknown007
I have to wait until my next oil change then.Where can I buy that oil at any auto store?Thanks Mike.
Paul I call but it goes to your house.
If anybody has a driver side fender let me know.My friend backed into my car.
goody90q45
WalMart or any auto parts store will have it. I have a passenger side fender, DS is gone. Sounds like an afternoon at Pick-n-Pull may be in order.
unknown007
Thanks.So you got a fender or I should go to pick n pull? I don't understand.Sorry.I'm looking for a good white one so I don't have to paint it.
kevinpaigeking
Car: 1994 Infiniti Q45
my 94 q45 is also ticking. Can the valves be adjusted on this car? ticking is less loud after car warms up, but is always present. did not occur until after an injector and knock sensor were replaced
jimbyjimb
The injectors on this car are audible with the hood up. An HLA tick is much more audible than injectors. Rev the motor and listen for its location. If it's coming from under a cam cover its a lifter. Do the MMO thing, or there are many treatments for sticking lifters. Auto transmission fluid works well, MMO as mentioned, Rislone, seafoam, on and on... It's not a huge problem. Varnish builds up in any hydraulic lifter after a time. Could take several treatments to repair.
unknown007
my ticking comes from under the plenum or maybe it's just the ticking confusing my ears.Me my teacher checked it out we figured it was the valves.He said to fix what I have to fix under the plenum and do it again.I really don't wanna take the plenum off agian, putting the injectors back in was suck a pain. Haven't had time either with school and all.
jimbyjimb
It will become much easier if you look at it like its not a pain and its easy. It actually is a fairly simple and straightforward procedure. You have done it before and you'll find it much less daunting the second go-around. Shortly you'll be able to whip it off and put it back together again in no time. I pinched an o-ring on one of my injectors and had the plenum off, injector re-sealed and plenum re-installed in less than two hours working at a moderate pace. I'm sure others here can whip that time. You'll get there. Just look at it as nuts and bolts, it's all it is.
kevinpaigeking
if it was a pinched o ring on new injector would unplugging the injector make it go away?
Q45tech
What they make stethoscopes for, to pinpoint engine noises.
yodawill2000
Car: 94 Infiniti J30
Or a 4 foot piece of Garden hose.
unknown007
I'll think about it mwahahahaha,
jimbyjimb
Citing examples on time frame. A pinched o-ring will not cause noise unless the cylinder fills with raw fuel to the point a rod bends, then you'll hear all kinds of noise. To any moderately trained ear there is an expressed difference in HLA tick and the injector click of the Q. HLA tick is very distinctive. Seems to be a common issue with the engine from reading past posts, and an uncommonly difficult issue to deal with. Most HLA on most engines one simple flush will eliminate noise. The VH is a stubborn old waif. Works well in many ways but not so much in others.
kevinpaigeking
what is a HLA? What is a VH? I do not understand how a new fuel injector could make this much noise. If I unplug the injector should the noise stop?
