So with my brothers 2001 maxima the throttle is stuck at 1500RPM minimum. If i put it in neutral the engive revs to 1500, i can accelerate as needed but this makes braking annoying because if i just tap on the brake the car will lurch forward. if i let off the brake the car will constantly accelerate... leave it long enough and it will get to 35-40mph on its own.... not the safest situation.
Im guessing its the TPS ... but i didnt know if the maximas had drive by wire or a throttle cable directly connected. is there an adjustment to the throttle body or cable that I can make so it doesnt idle so high and back to normal at something like 800RPM. thanks.
