How to clean IAC valve You will need;
10 and 12 mm sockets
3 inch socket extension
Swivel socket
Ratchet
Philip's screwdriver
rag
throttle body cleaner
1. Unplug the 4 connectors from the IAC assembly. Undo the hose that connects the IAC to the intake assembly.
2. There is a metal bracket that is blocking one of the IAC mounting bolts. Using a 10mm socket, remove the bolt that holds the metal bracket.
3. Remove the 3 mounting bolts using the 12mm socket. The lowest bolt may require the swivel socket.
4. Pull out your IAC valve and clean it w/throttle body cleaner, rag, and old toothbrush.
Now reverse steps 1-4.
How to adjust IACV -
1. Warm the engine up to operating temp.
2. Turn off the engine.
3. Disconnect the TPS.
4. Start the engine and adjust the idle speed using the stop screw on the throttle body to 650 RPM's.
5. Turn off the engine.
6. Reconnect the TPS and restart the engine.
If the IACV is working correctly your idle should be correct. If it's a bit low, try adjusting the screw on the IACV bypass to get your idle speed to 700 RPM’s in neutral with no load.
294 HP and 305 lb/ft TQ
Bone stock aside of a Cobb catted Down Pipe and
an Accessport tune done by Tim Bailey at Surgeline
| Quote, originally posted by Mr1der » |
if you ditched the Scooby for one (Nissan Rogue) I'd consider donating one of my massive balls so you could remember what it's like to not suck dick  |
