Throttle response
blind6
Car: was a 1997 Infiniti Q45
I have been searching the past couple nights (12hrs a piece at work) trying to locate some info about improving throttle response. Most of the cars I have worked on have a dizzy and wires. My 97 Q45 has thrown me a new curve and a need to learn more about this system. My 04 Durango had a coil setup and I used a spark advancer (not impressed ). Other than the NGK plugs, what are my options? I am 50-50 on the diff swap, but trying to stay more in the engine bay. So far I have seafoamed the intake and oil, used Lucas in the gas, added valvoline maxlife synthetic oil w/ restore additive, used octane boost w/ 92 fill-up, and just took out the rear muffler and put in two dynomax mufflers. I have noticed gains, but I am after responsiveness at the pedal. Any help would be appreciated, I know the manufacturer made it the way it is but I think some improvements can be made. I'm not trying to make a race car, i just want it to act more like a V8 . Thanks in advance
nchopp
Could you be a little more specific? Where is it you're looking for more performance? Low-end, high-end? I for one am very satisfied with the performance of my Q - keeping in mind it's a 4,000 pound car and will not be "quick" off the line without some significant modifications. (I.e. Wes's BAD Q)
blind6
What exactly has Wes done to his Q? I do realize this car has a sucky weight to HP ratio, but through experience with my Honda's and Acura's I've changed ignition components and noticed a better response when it comes to the throttle(I press the gas and it goes, no hesitation). That's ultimately what I'm trying to reduce is the hesitation between pressing the pedal and the vehicle going. Sorry that's the best that I can explain it, I can work on cars just can't spit out all the lingo.
blind6
zerothread?id=19631
It figures I'd find what I was looking for after I threw my link out there. Has there been any added info to this link since it is a little out dated?
nchopp
Oh, Wes's Q is probably the farthest from stock (mechanically) of just about anyone's around.
* Level 10 transmission with 3000 stall torque converter* MSW wheels- 17x8 in the front, 18x9 in the rear. Sumitomo HTRZIII 245/45/ZR17, Kumho Ectsa 245/40ZR18* Full custom Borla exhaust with gutted cats* 4.08 Rear End conversion* 100 shot Nitrous system, with JWT NOS, race gas fuel cell.* JWT ECU and TCU- Boosts performance and raises redline to almost 7500 RPM* Tokico Blues with Eibach springs* Stillen Front strut brace.* Cross drilled brake rotors* Stainless steel braided brake lines* Synthetic fluids throughout* Best 1/4 mile time: 12.6 at 108mph
Here's the write-up on it.
http://q45.spilky.com/bad/
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
chopp that stuff is fairly out of date... things have changed. i gotta change that crap sometime......
one thing that the factory did was retard engine timing when the car first started off..... this was so when you floored it, the car would not lurch forward...
remember that any 32valve V8 with a 4 speed auto (with grandma gears) in heavy car will not have very good low end response...
blind6
Wes,So out of all the above listed mods which would you say are worth keeping/trying?
elwesso
2007 BMW M Coupe
little of those are actually applicable to the Y33 Q and will make the car go any faster...
For you, id slap in a 4.08 differential and call it a day..... bottom line best mod you can do.
blind6
So the 4:11 gears, Jim Wolfe ECU, and transmission are out?
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
blind6 wrote:Wes,So out of all the above listed mods which would you say are worth keeping/trying?
I'd make sure it is running like brand new first, -if it's that doggy test the det sensors, and hook it up to a scanner.
Not sure what needs to be done to a Y33, but this would be my starting point. FWIW.
blind6
det sensors? not sure what your talking about. Some of the lingo is new to me. Unless I'm just slow and misunderstood.
Rex
Car: None
blind6 wrote:det sensors? not sure what your talking about. Some of the lingo is new to me. Unless I'm just slow and misunderstood.
I think he means Knock Sensors, that was the first thing I thought of when I read it.
blind6
That's what I was thinking also, but wasn't sure. Someone stated that along with the knock sensors you need to replace the wiring, is that sorrect or false info?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
blind6 wrote:That's what I was thinking also, but wasn't sure. Someone stated that along with the knock sensors you need to replace the wiring, is that sorrect or false info?
That's a;ways correct unless you want to repeat the labor when the harness fails soon after replacing the sensors.
Read in the Infiniti Mechanic Forum about KS replacement on a VH41DE.
elwesso
2007 BMW M Coupe
Yeah... DEFINITLEY dont even THINK about modding before everything is kosher... Take it to autozone and have them read the codes!!!
blind6
Can they read codes if there are no CEL's?
elwesso
2007 BMW M Coupe
yep, knock sensors dont throw CELs
blind6
And I'm learning.....We only have Checkers here in Hawaii, is there anything specific they need to test for? Or is it a basic diagnostic
elwesso
2007 BMW M Coupe
Its basic diagnosis... Theyll plug in the scanner and see if theres any codes.
blind6
So if it says no codes that's my green light to start doing other things to the motor? What kinda work do you do on ECU's and what kinda prices would I be looking at? Is everything vehicle specific as far as what mods are done or is it just what the owner wants to achieve?
elwesso
2007 BMW M Coupe
We dont do the ECU mods on the Y33 Q yet... Not looking too good either.
Vinsanity
Car: honduh 2000 ^_^
elwesso wrote:chopp that stuff is fairly out of date... things have changed. i gotta change that crap sometime......
I suppose that makes sense, but I swear the 97 STS I test drove before buying my car felt like it had better off-the-line response than my Q45...did Caddy actually not retard the timing on the Northstar?? please don't tell me they actually moved past using grandma gears while we still had em!
The STS is indeed quicker off the line and up to 80. But past that I think the Q has the advantage.
Vinsanity
hah. well damn if the Caddy I test drove didn't have the suspicious valve tap that kept me from buying it
I love your guys's icons
Flagship-Q
Car: 1992 Infiniti Q45
Hey Wes, on this subject, does the ECU program (G50) your working on address this or change any of the perimeters of the stock ECU program? What I mean is, does it change throttle response etc? Just curious if it can be programed for instant response and so forth. Thanks!
elwesso
2007 BMW M Coupe
Flagship-Q wrote:Hey Wes, on this subject, does the ECU program (G50) your working on address this or change any of the perimeters of the stock ECU program? What I mean is, does it change throttle response etc? Just curious if it can be programed for instant response and so forth. Thanks!
Yeah. the factory has (like I said earlier) ignition retard when you hit the gas.. Ours eliminates that...
Vinsanity wrote:hah. well damn if the Caddy I test drove didn't have the suspicious valve tap that kept me from buying it
Thats just from carbon buildup, easily resolved with some hard runs. The Seville and Eldo are great cars, and I might buy one in 06, but they dont hold a candle to the Q for reliability.
Vinsanity
hence my decision ^_^
at this point I'm willing to sacrifice 24 horses and the ghetto FOBulous image for something more likely to make it to the 200k mark
if the right one comes along, I definitely won't be passing it up, though
nchopp
Vinsanity wrote:at this point I'm willing to sacrifice 24 horses and the ghetto FOBulous image for something more likely to make it to the 200k mark
Pish, 200k is easy. I'm at 196 already and she's not even tryin'.
Vinsanity
well, some people would say that I'm not exactly easy on my cars. but if you ask me, I just think my cars don't like me (to the point where they'd rather die)
