For the seafoam, it comes in a liquid form (not aerosol, like BG44k)... It helps to have a small funnel, ideally we should have done it at my house since I have these little tiny funnels that fit perfectly inside the booster hose...
The other way you can do it is pour it into a small cup or something like that and stick the hose in the fluid a little bit at a time.. YOU DO NOT WANT TO FLOOD THE ENGINE OUT..... its easiest to have someone inside the cabin running the engine at 1500rpm or so..
Make sure the car is at operating temp first....
So the procedure would be1. Take off the brake booster hose, the one on the booster near the master cylinder......2. Figure out how your going to get the fluid in there, by one of the things i mentioned...3. Start the engine, run it up to 1500rpm (have a helper) and slowly add the seafoam through the hose... Dont let the enigne die, and it it struggles let off and then go again.... Under no circumstances should the engine die4. As soon as you add the whole can, immediately shut off the engine and let it sit for a while (20 mins or so)...
After this, take it out and run the poop out of it... Many redlines thorugh 1st and 2nd gears to blow all that crap out of there..
Be warned, you may not want to do this in a residental area, as it gives off a TON of smoke, so if someone would be offended you might go somewhere else.....
I have my sub installed but im still having problems with it, apparently my connections arent very good...
