I met up with andre today and drove his car. First off his car is in really nice shape (ohh to see Q leather not ripped is wonderful), hes a great guy and doing all the right things but this Q is really demon possessed... hey Im catholic maybe we could do an excorcism!
Symptoms: Car idles good, but is really struggling to run... Idle smooth, runs quiet, everything is normal... the car revvs very slow... Doesnt really shake, but it really is struggling to go... The car responds to shifts fine, kicks down normally.....
First thing we did was swap the MAF. No good.. My maf is good, and we put his maf on my car... Same thing, still very slow.....
Then we swapped the ECUs. Mine is a cal, his was a federal.. No difference in running..... He has a knock sensor code though.....
Then we checked fuel pressure. Just fine, around 34 at idle and 44 at WOT, fuel pump is nearly silent.....
Then we checked the TPS. we checked the resistance and votage and its about the same either way.. I cant remember the numbers (it was like 10 mins ago) but his was running just a little less than mine.. SOmething like 2.4 volts his was running and mine was like 3.4 or something along those lines.....
We then sat down to nice BLT lunch that my mom prepared for us!
Before hand I did an AT CHECK just for kicks and giggles, and I got a CODE D which means low battery voltage, or the battery has been unplugged for a while. This told us that the battery could be bad (even though its newish), so we checked the voltage, and it was like 12.5 just sitting there... We turned it on and it was like 13ish....
Then we swapped in my battery, and no difference there either......
So in summary we can conclude its NOT:
The ECUThe MAFprobably not the TPSbatteryfuel pumpinjectors
I am completely stumped and have no idea what to do...... Masters lets see what you got!
