Throttle cable - CA18DET
h0ivik
Car: 1992 200SX S13 CA18DET
Hi!
I'm unable to find a new oem throttle cable for the CA18DET engine, but I read somewhere on here that the cable from a KA works with almost no modification of brackets etc..
Does anyone know if this is true, and what part number the KA cable has? Found this on frsport 18201-54F00, but I'm not sure if it's the same length etc.
This is an 200SX S13 (LHD) by the way!
Thanks!
Hijacker
Car: '92 240sx Convertible
'94 F-150
That is indeed the correct P/N for the throttle cable on a USDM S13 with a DOHC KA.
https://forums.nicoclub.com/swap-guide- ... l#p2524193
Here it's mentioned the DOHC throttle cable works fine with a CA18.
h0ivik
Hijacker wrote:
Thu Nov 08, 2018 8:00 am
Thanks for the answer!
Found another article on here mentioning the KA SOHC throttle cable: https://forums.nicoclub.com/ca18det-thr ... 79053.html
Looks like it's the SOHC cable that works best with a CA? Gotta say that I'm a little bit confused here :confused:
Do you you know what the P/N is for the SOHC cable as well?
Thanks!
