Swap Guide, in the making
burntricer
Car: 90 S13 SR20DET Redtop
Im trying to make a list of EVERYTHING you need to swap into the s13 for a CA18DET
Add what you see that isnt here.
CA18DET MOTORCA18DET TRANNYKA24(D)E CLUTCH *NOT SURE ABOUT THE DE*CA18DET HARNESSCA 18DET ECUKA24(D)E MAF *NOT SURE ABOUT THE DE*ALTERNATORFMIC/SMICCA18DET INJECTORSALL CA18DET SENSORSALL NECESSARY BRACKETS/ACCESSORIES ON THE BLOCK (THROTTLE BODY/MANIFOLDS ECT)CA18DET FLYWHEELDOHC POWER STEERING PUMP/LINESS12 ENGINE MOUNTS (HOWEVER KA MOUNTS WORK)KA DRIVESHAFTDOHC TACH
like i said, if theres anything i missed please post!
Modified by burntricer at 12:57 PM 3/30/2007
sideways_13
Car: 91 s13
so you use th SOHC ka parts not the DOHC? i knopw you can use th ka clutch ka flywheel and ka driveshart and motor mounts... but is it the SOHC or DOHC????
im gettin ready to do this in my car in about a month or two...
burntricer
i think you can use both
Jiggyfry
I know you can use the KA24E MAF but can you use the KA24DE MAF?
superJoy
Car: 1989 RS13
Ignitor (or SR, VH, VG will work)Dropping resistor (or use one from a 1G DSM)Fuel pump, either the JDM or a Walbro (you may want to install a Nismo FPR if you do the Walbro)
If you're SOHC I'd get a DOHC throttle cable too. It's not entirely necessary, but the cable won't have to stretch across the valve cover and look stupid.
The secondary butterflys should be hooked up if you're running the stock ECU. This shouldn't be a big deal to do if you buy a clip; however, engine sets don't typically come with the components. Look for an '88 Pulsar NX SE in the junkyard or order the parts directly from Nissan. For more information look at the write-up in the stickies at the top of the forum.
I don't recommend using the KA mounts (the CA's exhaust side mount is a tad shorter IIRC), not sure about the S12 ones. If you want the engine to sit right in the car and the mounts that came with your set are toasted, try window welding them or buy the Nismo ones. Be cautious, they aren't the same as the SR ones.
Zero260
Car: 91 240sx coupe
I thought I read somewhere that if you're running basically a stock ca(ie. factory boost pressure), you can use the factory fuel pump?
superJoy
Car: 1989 RS13
You can, but I don't think it'll hold up for very long. I don't have any experience doing so, however, as I've got a Walbro and a Nismo FPR. Anyone know for sure?
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
sideways_13 wrote:so you use th SOHC ka parts not the DOHC? i knopw you can use th ka clutch ka flywheel and ka driveshart and motor mounts... but is it the SOHC or DOHC????
no ka flywheel buddie.
ka-e mafs, not de. e or de clutch disc and pressure plate is the same, difference is in the throw out bearing. they changed the tob carrier when they went to dohc.
this information already exists in a sticky by the way.
float_6969
All of this info is redundant. Please read the FAQ in the sticky at the top of the forum please, thank you!
burntricer
So it is aboslutley necessary to use the DSM injectors/dropping resistor?
Sil40sK
Car: '93 Nissan 240SX
'88 Porsche 911
'02 Ford Focus SVT
burntricer wrote:So it is aboslutley necessary to use the DSM injectors/dropping resistor?
No, it's just a replacement if your stock CA ones are fubar or just not there.
burntricer
k cool
