I successfully completed this job:
coolant-leak-crossover-pipe-gasket-t600711.html for my '01 QX4; however, when I went to test-drive the car afterwards, my throttle is acting up when the car shifts from 1st to 2nd and from 2nd to 3rd gear.
When it shifts from 1st to 2nd, the throttle "flutters" [that's the only way I can think to explain it] just a couple of times, causing the car to slightly jolt forwards and backwards; but then the car behaves normally after it shifts. And when it shifts from 2nd to 3rd, the RPMs jump from approx 1500 to 3000 for just a second, then it behaves normally. I test-drove it up to approx 60mph, and there were no other inconsistencies seen/felt.
I'm trying to narrow down what would cause this. What do you think could be the culprit?
Thank you all for the help!
