tabrown11 »
https://forums.nicoclub.com/tabrown11-u238060.html
Mon Jun 08, 2015 5:31 am
I have an update and a question:
- I was able to remove the upper and lower intake, and remove the four nuts off of the studs for the crossover pipe. The problem I am having now is moving the crossover pipe along the studs, away from the engine, to gain enough clearance to remove the old gaskets and replace them with the new ones, because of the hoses attached to the crossover pipe.
- Referring to page LC-17, do I need to detach the water hose [#4] from the water outlet housing [#1] and the hose that attaches to the left side [facing the back of the engine] of crossover pipe to gain enough clearance to replace the two gaskets? If so, what techniques/tricks do you know of to remove those?
Thank you again for your help!
