mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Wed Jan 13, 2010 7:46 am
Here are the pictures of the two fuel pump controllers. The one on the right was in my car and the one on the left was supposed to be a working spare. As you can see the ground terminal on the one on the right had gotten hot and so I did re-solder the terminal so that isn't the problem now and I didn't see any signs of the transistors getting got. IE: No signs of the solder melting nor the circuits them selfs getting over heated. The one on the left looks like new inside, especially the connector, and I didn't find any problems with the solder there either. I added the wire to it before I hooked it up just to help spread the load a little better.
I mentioned in the other thread that I posted in IOM that the fuel pump and controller both came out of a 1995 Q that we had for parts and it had somewhere around 60K on it. When my fuel pump went bad, I pulled the controller and pump from that car and put in mine. The pump sounds as good today as it did when I put it in, practically silent.
As far as fuel filter goes, I do all my service on a regular basis so, no problems there.
