Simple the pump has 2 wires, one goes to fuel pump relay [where it gets +12volts] and the other goes to FPCU [ where it gets a ground [WOT] or low [cruise] or higher [idle] resistance to ground depending on ecu controlled speed requested].Get a 3 position 15 ampere single pole double throw with center off position switch. Interrrupt [cut/splice to switch as needed] the wire from pump to FPCU.
Fuel pump control unit 0------------0fuel pump-----------------0 Frame ground
To the left the fuel/pump is connected to FPCU
Center off = no connection to pump
To the right the pump is grounded to frame chassis and runs without FPCU.
Or just remove the fuel pump fuse or insert a purposely blown fuse.
Or disconnect the cable to FPCU.
Lots of fuses will stop car from cranking, running.
What about a time delay switch module that cuts pump off after a preset time in seconds.
It is assummed that the switch would be mounted inside rear storage to avoid lengthening wire [too much] from pump to FPCU which would add resistance and skow pump rpm down.
Copyright 2010. Nipuspan International Corporation. All rights reserved. This material may not be broadcast, rewritten or redistributed.
http://www.t3atlanta.com/
