thoughts on clear coating zenki headlights to prevent them from dirtying?
jt15833
Car: 95' 240SX
Every few months I have to give my headlights some tlc. I used to sand them with low grit to high grit and use aluminum polish but I heard about a wheel they sell at napa you can attach to a drill and do the job much quicker.
My question is, would clear coating the headlights after cleaning them prevent future contamination?
Would the clear coat just dirty and make it more difficult to clean?
Would clear coat have a negative effect on lighting? Either to me or oncoming drivers?
ThanksJon
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
I just hit mine with a buffer and some mag polish every few months, only takes me a few minutes, its not that big of a pain. I would imagine that any clear coat that will adhere to plastic wont be much harder than the plastic itself, it will most likely yellow in the same way the plastic does..
got chub
Car: pearl white 95 240sx
i just use the wheel you were talking about from auto zone ever few times i wash my car
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
i had the same thought a while back. cleaning up the lights then hitting them with some wheel paint clear coat. I say it would protect them better than nothing. i mean the clear coat on your car doesn't get faded and nasty every few months does it?
go for it and let us know how it holds up!
IanS
Bronze MFP wrote:the clear coat on your car doesn't get faded and nasty every few months does it?
Flawed logic, you car body is not made of clear plastic. Plastic headlights yellow due to absorbing sunlight, I fear that clear coating it will not stop that absorption.
Bronze MFP
I see what you're saying. i thought clearcoat was a uv protectant as well.i always figured my headlights got yellow from all the construction dirt kicked up on them. they're always building something around here.but the uv bit makes sense.
f-it, just get the german glass headlights
Addicted2Kouki
if you use automotive paint clearcoat. if would work.like PPG or something.but i think youre asking about a rattlecan.those...wouldnt work so good.
