21" exact tire to simulate a 4.36 and such a thing probably doesn't exist in 15".
A 195/60/15 ~~ 24.2" so that might simulate a 3.80 diff
A 195/50/15 ~~ 22.7"....................................a 4.04 diff........
At least a [195/50/15] 1019 pound load index tire would probably be good enough to try drag time on the rear but we already know mathematically what the results will be!
A new nissan 5 speed AT with a 3.54 1st gear [with a 3.538 stock diff] would simulate a 4.49 diff gear with a 4 speed transmission.
Now that most G35 and all RWD have this 5AT transmission probably time to consider building adapter plates housing to fit this in a 90-01 Q........the junk yards will have them by now [2 years after first use].
The end result: cruise rpm will be 2300 rpm roughly what a 4.083 creates, assumming Nissan recreates the 5 AT gear set for 2005/2006 you might be able to future swap a better gear span [rartio spread] in another two years.
Current 90 span 4.0, 2004 span 4.4, guessed future span 5.1 unless they have a 6speed AT in the wings.
"Extra gears facilitate a broader ratio spread between launch and cruising ratios. The new ZF automatic has a 6.05 ratio spread between first and sixth compared to 4.0 for the typical four-speed, 5.0 for five-speed automatics, and 5.5 or so for wideratio five-speed manual transmissions. According to ZF's Executive Vice President for R&D Michael Paul, the 6.05 ratio spread is optimum for today's engines but direct-injection gas and diesel power-plants of the future may appreciate even broader spreads. When asked if that means ZF is investigating seven-speed automatics, Paul acknowledged that single-digit fuel efficiency gains are possible with them but refused to confirm that his engineers are actively pursuing that approach."
http://www.mathworks.com/acces....html
