Sinister350GT »
https://forums.nicoclub.com/sinister350gt-u136290.html
Mon Jun 15, 2009 8:39 am
G35 Twin Turbobuilt VQ35DE ShortBlock From Import Parts Pro.
The stage 2 package block includes:CP Pistons .020 overPauter RodsARP Rod Bolts L19'sRev-Up Oil PumpRotating assembly balanced to 50%Crank magnafluxed and the journals micro-polishedNew Ceramic coated Race Spec main bearings installedNew Ceramic coated Race Spec rod bearings installed
Head Package:SW1 Jim Wolf Upgraded Cams 260 DEG DUR. / .428"(10.9MM) LIFT, INT. ADVANCED 2 DEGREES. *JWT Heavy Duty Valve SpringsPorted exhaust and intake runners5 angle radius cut valve jobCometic Head gaskets
Greddy TD05-18G Twin Turbo Kit 2x cast-iron manifolds, 2x ext. Type T wastegates, 6x RC 750cc inj., 2x Airinx AY-SB, piping & necessary hardware.
Upgraded Walbro fuel pumpCJ Motor Sports Full Fuel Return KITGreddy Front Mount Intercooler -Weapon R Oil Catch CanWeapon R Power Steering CanGT-Spec Braces - Ladder Brace Sub Connectors AllTein H-Tech Springs20' Axis Shine with BF Goodrich RubberGreddy RS Type Blow Off Valve.Plenum Spacer 5/8"CJ Motor Sports Fuel Return Kit & 255 Walbro Fuel Pump.TS Carbon Fiber HoodCarbon Fiber TrunkTurbo XS KnockLite/Shift lightTurbo XS Tuner Wide Band O2 SystemGreddy Profec-B II Boost ControllerGreddy Turbo TimerStage 4 Race Clutch and Light Weight Fydanza Fly wheel Amico Clutch USAKoyo Rad with mod Elec fans2 Nascar Brake Cooling FansNismo T-Stat and Rad CapSnow Performace Meth kit Stillen SwaysVooDoo CARPC running Uprev Cipher/Osris for Tunningfirst run:12.77 @ 116 mph
