This is what I found when i took the head off. Need suggestions
chicos240
Car: 1995 240 SX
I took my head off, because of a blown HG but I found more than what I bargained for. I need suggestions.Full rebuild?Patch the wall?
Emperor_Tha
bore it out and get some sleeves.
hpmachine
Car: '05 EVO8 + '95 240sx
Dude is that a hole punched in the valve?
jr_ss
Car: 95' S14
You're going to need to get a full rebuild done. You melted or your car melted that piston and where the hell did that piece of valve go? Wow man, that sucks. Good luck getting it back up and running.
chicos240
Car: 1995 240 SX
yes it is...but I think thats from when I took the head off, i heard the valve "clink". Do I NEED sleeves if I bore it out? Also why are after market pistons so damn expensive?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
can anyone say lean condition
chicos240
Car: 1995 240 SX
yea i will need a full rebuild.....argggghhhh!!!!I have no clue where that piece of valve is
jr_ss
Car: 95' S14
They are so expensive because they are forged. Just like wheels cast is cheaper than forging. I don't think your crank and what not is damaged, so you might be able to get by with just a bore and some new pistons, but I'm not a machinist and can't tell you that for sure.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
id buy a new long block, or take those pictures to a machine shop, and see if they have a better suggestion. bore the hell out of it maybe??
Deadrodent
Car: 1992 240sx hatchback
dude that totally blows paralyzed midget pen15. what kind of setup were you running? this kind of thing makes turning up the boost on my motor VERY scary
chicos240
Car: 1995 240 SX
dude it wasnt boost. It was bad luck. Oh well. Anyone have a long block in their back pocket?
hpmachine
bad luck generally doesn't melt pistons and bust valves.
chicos240
Car: 1995 240 SX
ok, the bad luck of possibly having a vacuum leak, that created a misfire that then curled the piston...then somehow blowing the HG, then wile removing the head having the bad luck to break a valve
GTS4-R
Car: my feet
bore it out???!!! do u guys not see that massive hole in the wall (sleeve) he MIGHT be able to press out the factory sleeve or cut em then bore the block and install new sleeves and pistons but thats still maybe....i'd tell you ro find a short block somewhere
Slipstream
Car: '94 Sonoma, '90 300zx n/a
That looks like it's too far out to just bore it to a larger piston. Best bet would be to sleeve it or find another block. I would check the entire rotating assembly to make sure everything else is fine. The metal knocked off the piston, ring, and bore had to go somewhere.
ps: I have a spare block, but it needs to be honed for 87.5 pistons though.
chicos240
Car: 1995 240 SX
you have a spare s14 block? that just needs honing?
Hijacker
Car: '92 240sx Convertible
'94 F-150
I can't see the extent of the damage in the photo., so I'm just gonna say this:Stop speculating. Tear the block down and take it to a machine shop. Have them assess the damage and tell you your options. If they have the block in hand, they can give you your options better than showing them a picture that doesn't give the full depth of the damage.
Slipstream
It's an S13 block. I had 86.5 pistons, and didn't want to buy new ones.
