this is for the smart ones! - oil pan bolt tread size
Kalypso
My oil pan is leaking because the tread in my block for a bolt is stripped,
whats the diameter and tread size for an oil pan bolt.
I need a tapping tool to retap that hole and I need on that is the right size
Modified by Kalypso123 at 5:57 AM 6/11/2008
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
It is either 4 or 6 mm and IIRC the thread pitch is fine.
BigMACKenzie
Car: 1993 Nissan 240SX convertible
I would reccomend ordering a magnetic drain plug, you can probably pick one up for less than $20.
IanS
BigMACKenzie wrote:I would reccomend ordering a magnetic drain plug, you can probably pick one up for less than $20.
The block is made of aluminum, a magnet wont do any good.
Kalypso
fine thread - coolother fine bolts have tread count 1.25 so I can assume its the same
what tool can I use to bore out the thread again.there is a liquid solution but it seems shady
Im going to look around
IanS
Kalypso123 wrote:fine thread - coolother fine bolts have tread count 1.25 so I can assume its the same
Use a tap and helicoil.
Kalypso
thank you
