Seven3Lee »
https://forums.nicoclub.com/seven3lee-u123049.html
Tue Apr 02, 2013 11:17 pm
Okay, so I rebuilt the engine on my car. It started fine before I tore it down and apparently I didn't put something back together correctly. Here is what I have going on:
Clue #1: When I turn the key to ACC, the dash lights up like it should, but there is an audible buzzing sound which sounds like it is coming from the front of the car someplace. This lasts for about 6 seconds. If I turn the key while it is making this noise, the car does nothing. If I wait for the noise to stop, I can start the car normally.
Clue #2: The car idles perfectly, with no surging, hunting for idle or anything. Rock solid. With it sitting in neutral, I can rev it normally as high as I can go. When I put it in reverse, it goes backward with no issues. If I try to go forward, it runs like a champ until 3500rpm and stops. I get nothing at that point. I even tried shifting to 2nd and still nothing past 3500.
Clue #3: If I do not move the car and let it idle, it will idle for as long as I let it. There is a slight burning smell, which I am assuming is the piston rings seating, seals settling, etc that is normal with a newly rebuilt engine. If I have tried driving the car for any length of time, there is a thin, wispy white smoke coming from the exhaust. It isn't anti-freeze, as it doesn't have that distinct burning anti-freeze smell.
Any ideas on where to begin?
